Embedding an HTML Iframe in Arcgis Online Popup
topotoma
Forum|alt.badge.img+3
Hello,
I have been trying to figure out how to embed a website in ArcGis Online popups but could not get it to work.
I have tried the method to have an attribute with the Iframe code as some suggested in earlier version it was interpreted correctly but it seems this is not the case anymore.
I have found that there’s a way to embed video for example but nothing for integrating a website.
So if you have any suggestion that would be great. Thanks.
Thomas
Best answer by topotoma
Hello,
I finally got a reply, for security reasons ESRI have blocked the option in integrate a webpage in the popup.
In case this might be useful for someone else.
Best regards.
Thomas
nielsgerrits
Forum|alt.badge.img+56
Hey Thomas, no offence but you’ll probably get better / more reactions on an ESRI forum as this is not an FME related question.
topotoma
  • July 18, 2024
Thanks, I thought I could delete this question but it seems that there’s no option to do so in the forum.
I also created another question by mistake exactly on the same topic which I can’t delete either…
Sorry about it. If an admin reads this message both questions can be deleted from the forum.
topotoma
  • July 24, 2024
Hello,
Best regards.
Thomas
