I’ve been creating some workbenches that regularly update datasets on ArcGIS Online, but I’ve hit a small issue with the ArcGIS Online authentication within FME. It’s fine when I run the workbench, but if someone else runs the workspace they need to use their own AGOL account. I’ve added the workbench into an ArcGIS Pro toolbox as an ETL tool so it can be scheduled in Pro, so is there anyway to pass a persons ArcGIS Online account info from Pro to a FME workbench? Or force it to need a login prioir to running.
