Do the REST API parameters match with those of the FME workspace user parameters ?
  • Feb 12, 2019 11:15 AM UTC
  • 75 views
I am trying to run a job on FME server through REST API and want to pass user parameters through it. How do I know which parameters of the particular transformers are exposed to the REST API ?
Best answer by david_r
You can only reference the workspace published parameter through the REST API, e.g.:
So if you need to set a transformer parameter using the REST API, you have to publish that particular parameter first.
nielsgerrits
Forum|alt.badge.img+67
Not sure if I understand what you need. The published parameters from a workspace in server?
get /repositories/< repository >/items/< item >/parameters will return those.
  • Feb 12, 2019 11:42 AM UTC
