Data Interoperability & paramaters
  • February 19, 2025
  • 39 views
janrykr
Using Data Interoperability in ArcGIS Pro - Is there a way to pass attribution from selected features in a map/table to the ETL tool?
Edit--
Use Scenario: A data editor using a map in ArcGIS PRO selects a feature or multiple features. The globalids of the selected features are then passed onto the ETL toolbox and subsequently, the FME workspace performs a translation with just the selected features.
j.botterill
Forum|alt.badge.img+40
  • February 20, 2025
Hi janryjkr, I think what you are asking is in Workbench is
  • Tester or TestFilter inputting a condition to filter the incoming features to output ports you specify (pass/fail or customise)
  • Connect the output port with the selection, to a writer destination format (specify the feature type as the table name),
    • does the table exist - consider the feature operation Insert. Update etc and whether table operation is to truncate existing or use existing.
    • table doesn’t exist - use the table operation Create If Needed
I suggest reviewing this article https://support.safe.com/hc/en-us/articles/25407430413837-Tutorial-Getting-Started-with-FME-Desktop and completing the FME Academy basic course work, seek out the database writing to understand how to write to map/table
janrykr
  • February 21, 2025
No. I am asking how to integrate Data Interoperability with active selection in APRX document.
j.botterill
  • February 24, 2025
Not aware such functionality exists from the ESRI end. If it does, I’m keen to know of it.
As far as I know, Esri only allows you to launch a New or existing FMW workbench file.
