Configuration of a token based WebConnection
  • Sep 20, 2023 6:21 AM UTC
  • 274 views
tschoppenhof
Forum|alt.badge.img+7
I wan to connect to a REST-API with a WebConnection (Token Service), but it doesn't work with the paramters i use. The same parameter in a HTTPCaller are working. Any Idea whats wrong? The token is assingned to the key "jwt". I use FME 2023.1.
Example Settings for the HTTPCaller
Request URL: https:www.test-example.com/backend/api/AUTH/login
HTTP Method: POST
Headers: Accept text/plain
Upload Body: {"email":username@test.com, "password":"12345"}
Content Type: JSON (application/json)
And the answer looks like
(the values are not real)
               "user": {
                              "id": "123qw14-a666-222e-777a-a123fg2f12ad",
                              "email": "usename@test.com",
               "jwt": "0a80da980d80a7f7sd073",
               "userConfiguration": null,
               "globalConfiguration": {
                              "tileApiKey": "123sdgf43254e6sZZU347"
               "maxTables": 8,
               "maxColumns": 50,
               "language": null
My Web Connection Settings are like this:
Request Data: email[username@test.com]&password[12345]
Token Object Key: jwt
Placement: Header
Header Format: Authorization: Bearer [jwt]
Best answer by itsmatt
Here's one which I've configured in the past which works
It might be you need to change the structure of the Request Data to be JSON so it matches the POST body.
You may also need to change your Token Object Key from "jwt" to serviceResponse.jwt
The header format should use the TOKEN keyword I think rather than "jwt".
I notice in the response there is no expiry for the token - I'm not sure if FME requires/expects it.
Do you have access to the host to see the requests coming in to see if the structure is correct?
itsmatt
Forum|alt.badge.img+48
  • Sep 20, 2023 7:59 AM UTC
tschoppenhof
  • Sep 20, 2023 8:54 AM UTC
Hey virtualcitymatt
Thanks a lot. You were absolutely right, changing the request aus you suggest, did the trick. The expiry Time is not necessary.
