Calling FME Server via C#, I want to report status back to user when calling process
  • September 28, 2017
  • 8 views
dfresh
I am using C# to call FME server and want to report messages back to the user. say I have a workbench and I want to post a message "Halfway Complete", then in C#, I would continuously check the feed, and relay any messages posted from that workbench,
Cheers,
Best answer by stalknecht
You can communicate through websockets. For FME you can use the WebSocketSender and WebSocketReceiver. Optionally you can use FME Server Notifications. Here is a C# library that uses websockets (websocket-sharp):https://github.com/sta/websocket-sharp#websocket-client
danilo_fme
Forum|alt.badge.img+45
  • September 29, 2017
Hi @dfresh,
That is a interesting topic.
To use the integration between FME Desktop and Server has the FME Server Playground: C# Request to FME Server.
Thanks,
Danilo
stalknecht
Forum|alt.badge.img+19
dfresh
Thanks @stalknecht, I will be using websocket-sharp and the sender/receiver transformers.
