ArcGIS Enterprise Portal: Fail to update layer with Change Detector
  • Sep 13, 2023 1:02 PM UTC
  • 179 views
Hello all,
I am trying to update a feature layer on the ArcGIS Enterprise Portal.
I have the feature layer and an Excel I'm using for the updated information.
The change detector detects the one change I've added to my test version but when I try to update the online layer I get this error message:
"ArcGIS Portal Feature Service Writer: 'updateResults' error for a feature in 'C1_Cluster_Flurstueck'. The error code from the server was '10500' and the message was: 'Cannot convert a value of type 'java.lang.String' to 'INTEGER'.'"
The values that I'm trying to update in the excel and in the layer are both text fields and not numerical hence I dont understand where the integer part is coming from.
Can someone tell me if I'm using the right transformers and what I should change to make it work?
Thanks in advance!
(I'm fairly new to FME so any help regarding the workspace is appreciated)
j.botterill
Forum|alt.badge.img+69
  • Sep 13, 2023 5:54 PM UTC
For the text fields, what have you set as "Type" on the Writer - user attribute definitions. I don't think esri like 'Integer' type having empty/nothing values... so check the text fields have values... using the NullAttributeMapper might help Portal_featyreservice_writer
  • Sep 14, 2023 8:02 AM UTC
Hi, thanks for your reply. There are no empty fields. I've tried the NullAttributeMapper anyway but sadly that wasn't it. The user attributes have the following types. imageimage
j.botterill
  • Sep 14, 2023 8:41 AM UTC
hi utepla, can you send a screen grab of the Portal feature service - 'Data' tab and show the field names.
Each time you write to Esri the objectid is the primary index. Appears you are trying to write objectid_12 so this is perhaps where the issue resides
objectidsAlso you don't need to write SHAPE_% attributes, drop these on the writer,,, as these are calculated again in the feature service
