API Watcher in real time
  • Jul 9, 2020 2:45 PM UTC
  • 77 views
philippeb
Forum|alt.badge.img+23
Hello World,
I have access to an API where I can download features from a database.
We want to be warned each time there is a new feature in it. In live.
Is there some kind of API Watcher in FME Server I could do that?
Running a workbench each minute isn't the best option for us though.
Thanks!
Hi @philippeb
I think this is something that you'd have to set up on the database and use triggers to get the database to notify FME Server every time there is a new feature. You can check how to do it by searching online for your '<databaseType> triggers to webhook'. You might need to use another tool to allow the database to send data to a webhook.
We have a few articles on database triggers but I don't think they have been updated in a while.
If you don't have access to the database like that, unfortunately a regular scheduled job may be your best approach.
itsmatt
Forum|alt.badge.img+48
  • Jul 10, 2020 9:02 AM UTC
Automatons has an HTTP call option - not sure if this can be of uses on a 1 min schedule.
otherwise you should check out node red: https://nodered.org/
You can probably use this to process the response and send a request to FME Server. Only problem is you need to install node. But it's free...
