API call to external resource works in POSTMAN but doesn't work in httpcaller
  • December 13, 2018
  • 236 views
Hello:
I have an external resource that has an API that utilizes basic authentication using a token.
When I run the api call using postman or other REST API testing software, I get an OK response.
When I try running it using the httpcaller, I get a:
HTTPCaller(HTTPFactory): Received HTTP response header: 'HTTP/1.1 403 Forbidden' message.
Inspecting the response body gives:
{"code":"rest_forbidden_context","message":"Sorry, you are not allowed to view entries","data":{"status":403}}
I know that the api is working because it works in POSTMAN and other REST API testing software. What am I missing to get http caller to work?
I'm new to APIs and to FME. I'll be happy to provide any info needed.
Thanks!
Herbert Cruz
Here's the input on FME.
And here's the RESTLET testing input
Thanks everyone!
Best answer by yong_sa
I figured it out. Instead of putting the API token into the authorization header, I had to put in a username and password combination encoded in base 64 to successfully get information from the API.
Thanks!
Hi @yong_sa, can you share the details of the request that is working in POSTMAN?
- URL
- Headers
- HTTP Method (GET,POST, etc. )
- Body (if applicable)
Thanks
  • December 13, 2018
URL: https://pocoworks.portcoquitlam.ca/wp-json/frm/v2/entries
HTTP Method: GET
Headers:
Authorization : "API TOKEN FROM RESOURCE"
Body: None
  • December 14, 2018
Thanks!
Thanks!
Great! You could also use the Authentication option in the HTTPCaller and just enter the username and password. This will generate the header with the base 64 encoded string for you.
