Archived
Zoom-to-feature-Function in Table View in Data Inspector
Related products:FME Form
Despite the statement from this post that the Zoom-to-feature-Function in Table View of Data Inspector is implemented:
https://knowledge.safe.com/content/idea/35681/zoom-to-feature-function-in-data-inspector.html
I could not find Zoom-to-feature-Function in the tableview context menu. I really miss this feature.
FME Version 2020
Forum|alt.badge.img+49
You can select a feature in table and then use the "Zoom Selected" option on the main toolbar, will that work for you?
chrisatsafe
  • April 9, 2020
Hi @ifitch,
The Zoom to Selected functionality is only available if you right click in the map view: https://www.screencast.com/t/q6TdL9X3X4
Note: You can select the feature in the table view and then right click in the map view to "Zoom to feature"
  • January 29, 2021
The method that you described really works, but it requires extra movement in the interface. A good alternative is to use hotkeys that already work. Thanks
LizAtSafe
Forum|alt.badge.img+15
  • February 10, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
