In Development
New Reader/Writer: Apache Iceberg
Related products:Integrations
  • Sep 12, 2023 11:32 AM UTC
  • 13 replies
  • 488 views
t_hohenstrater
Level up to the parquet format (updates and snapshot)
LizAtSafe
Forum|alt.badge.img+26
  • Oct 29, 2024 9:48 PM UTC
Open→Gathering Interest
LizAtSafe
  • Oct 29, 2024 9:49 PM UTC
LizAtSafe
  • Nov 4, 2025 11:52 PM UTC
Gathering Interest→In Development
adrian_farrell
Is there any update on a planned release of this reader/writer?
LizAtSafe
  • Mar 4, 2026 11:13 PM UTC
In Development→Archived
LizAtSafe
  • Mar 4, 2026 11:15 PM UTC
Archived→Open
PierreAtSafe
Forum|alt.badge.img+11
​@adrian_farrell Sorry Adrian for the delayed reply here! We hit a little snag on the Iceberg front but it’s still on the roadmap for sometime later this year.
Cheers
LizAtSafe
  • Mar 31, 2026 11:19 PM UTC
PierreAtSafe
Hi everyone,
We are back in active planning on the Reader and Writer, and I want to make sure we build what you actually need first. If you are evaluating Iceberg or already using it, I would love concrete detail on your setup and the workflows you want FME to cover.
A few specific things that would help us prioritize:
  1. Read, write, or both? Which one would be the most important?
  2. Which catalog are you on (or planning to use): REST, AWS Glue, Hive Metastore, Nessie, Snowflake Open Catalog / Polaris, Unity, BigQuery, other?
  3. Which engines also touch these tables: Spark, Trino, Flink, Snowflake, BigQuery, Dremio, DuckDB, Athena, other?
  4. Where does the data live: S3, ADLS, GCS, MinIO, on-prem HDFS / POSIX?
  5. Rough table scale: rows, partitions, typical file sizes, how often you write.
  6. Write patterns you need: bulk load, append, full overwrite, row-level UPDATE / DELETE, MERGE / upsert, streaming?
  7. Geospatial: are you storing geometry in Iceberg today? As WKB in a binary column, as GeoParquet, waiting on native v3 Geometry?
  8. Any must-have features beyond the above: time travel, branches / tags for Write-Audit-Publish, partition or schema evolution, specific transforms?
An example workflow you are trying to build (source to Iceberg, Iceberg to target, or both) is worth more than a checklist answer. If your setup is sensitive, feel free to DM instead.
Thanks for the patience on this one. The more real use cases we hear, the better the first release will be.
Cheers,
metsatestaa
Participant
  • Participant
  • Jul 22, 2026 5:18 AM UTC
  1. Read or write: Both, Writer is the priority.
  2. Catalog: AWS Glue (planned).
  3. Engines: Athena (primary), Python, DuckDB in some PoCs.
  4. Storage: S3.
  5. Scale: Mixed — largest ~1.28B rows (~180 GB) and ~2.7B geometries; target file size 128–512 MB.
  6. Write patterns: One-time bulk loads + daily CDC (append).
  7. Iceberg and GeoParquet/Parquet side by side.
  8. Must-haves: Partition evolution, schema evolution.
Main pain: FME processes PostGIS data and needs it to land as an Iceberg table on S3 that Athena can query. FME writes the Parquet files without committing them to the Iceberg table / Glue.
PierreAtSafe
Hi ​@metsatestaa,
Thank you for the info there, extremely valuable to us!
We are focusing on the reader first with the goal to roundtrip data, but the writer will come soon after, with Glue support.
Cheers,
LizAtSafe
  • Jul 31, 2026 7:17 PM UTC
PierreAtSafe
Hello there!
Just a quick mention as we are releasing a first version of the Apache Iceberg reader today in Technical preview with FME 2026.3. There are quite a few changes coming to FME 26.4 but people eager to give it a try will be able to as of today!
Let me know if you encounter any issues.
Cheers
