Open
JSON Formatter in HTTPCaller
Related products:Transformers
  • August 20, 2024
  • 122 views
warrendev
I would like to see a built-in option in the HTTPCaller transformer to format the response body for development purposes. I know that the HTTPCaller in 2024.2 has the “HTTP Test Request Preview” that shows the response body formatted, but it would also be nice to have the attribute “_response_body” formatted instead of having to use an additional transformers “JSONFormatter” or “XMLFormatter”.
Example of HTTP Test Request Preview
There could possibly be a toggle to format the response body, or to keep it in raw form. Instead of using the JSONFormatter or XMLFormatter, I would like to have the response body formatted directly in the HTTPCaller.
LizAtSafe
Forum|alt.badge.img+15
  • January 3, 2025
NewOpen
alexbiz
Forum|alt.badge.img+14
  • July 8, 2025
Hey ​@warrendev
have you tried this ?
salvaleonrp
Forum|alt.badge.img+16
  • July 8, 2025
Some APIs have that option…. like ESRI’s Rest API... f=pjson. For authoring and for formats that do not have the pretty option, I use what ​@alexbiz suggests.
warrendev
Forum|alt.badge.img+24
  • July 10, 2025
Hi ​@alexbiz, I’ve actually been using this method, and it works well, but I’ve noticed when working with different API responses within a workspace, XML and JSON for example, I have to switch it back and forth in the different HTTPCallers. It’s not really an issue though, and it is very useful to have the option to change the syntax formatting.
