Archived
Harmonize access key settings of SQS and S3 transformers
Related products:Transformers
  • Dec 15, 2015 12:00 AM UTC
  • 82 views
geosander
Forum|alt.badge.img+7
Currently, you need to specify a "hard-coded" AccessKeyId and SecretAccessKey for the SQSReceiver/Sender/Deleter/MessageCounter, or you can set it through a Public/Private Parameter.In the S3Downloader/Uploader/Deleter/ObjectLister, you can omit these values and get them through a file, Java system properties or environment variables. I think it would be nice if this behavior is consistent among these AWS transformers.
donatsafe
Forum|alt.badge.img+4
  • Dec 15, 2015 5:32 PM UTC
Great one Sander. Consistency. Sorry we missed that. I will create a PR!
geosander
  • Jan 20, 2016 11:27 AM UTC
Any news on when the PR is due, @donatsafe?
We are now using IAM Roles on our EC2 instances. This works perfectly with the S3 transformers. Would be nice if the SQS transformers picked up the credentials from the IAM Role as well! Same goes for SQS publications/subscriptions on FME Server, by the way.
Now I am implementing some Boto solution, because we don't want to pass credentials as parameters to a workspace.
Thanks! :)
