Open
Easily override zip-file name on FMEServer Datadownload
Related products:FME Flow
sigtill
Default filename using the DataDownloadservice is : http://fmeserver/fmedatadownload/FME_2D764B0C_1515155526785_73956.zip
Create an FME_SERVER_PARAMETER on FME Desktop like : FME_SERVER_ZIPFILENAME that can override this name if not empty. Then you can easily create a complex output-file based on both published parameters and attributes created during the workspace. For instance in a workspace you have:
PUBLISHED PARAMETER
Startfilename = "3Dmodels"
attribute created within the workspace:
timestamp = "20180101"
FME_SERVER_ZIPFILENAME = "Startfilename + _ + timestamp"
Will give the filename:
http://fmeserver/fmedatadownload/3Dmodels_20180101.zip
and automatically this will be the downloadlink instead of the default:
  • January 6, 2018
Agree that the suggestion would be useful in some cases. I think it would be better if the resulting zip file path could contain not only timestamp but also Job ID, in order to make each file path completely unique. Since the same workspace could be run with multiple jobs at the same time.
virtualcitymatt
Forum|alt.badge.img+36
Still don't know why this isn't a feature. The UUID of the zip is a bit of a pain
  • September 27, 2022
Is this still not possible?
LizAtSafe
Forum|alt.badge.img+15
  • June 15, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
panda
Forum|alt.badge.img+18
  • March 28, 2025
Could use the name to include DateTime stamps!
rylanatsafe
Forum|alt.badge.img+13
