Released
Disable All Transformers inside Bookmark with the Disable Shortcut (CTRL-E)
Related products:FME Form
We can disable transformers or even a selection of transformers using CTRL-E but it would be useful to simply click on a bookmark and press CTRL-E rather than having to right click and disable through the menu.
It should probably be enabled only for bookmarks with the magnet turned on.
LizAtSafe
Forum|alt.badge.img+16
  • February 10, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • February 10, 2024
dustin
LizAtSafe
  • February 10, 2024
LizAtSafe
  • April 5, 2025
jennaatsafe
Forum|alt.badge.img+4
This is available in 2024.1 onwards. You can now click on the bookmark, and use the shortcut CTRL + E to change state of all transformers in a bookmark between enabled and disabled. There is also a corresponding menu item “Disable All Objects In Bookmark” accessed by right-clicking on the bookmark.
jennaatsafe
In DevelopmentReleased
