Open
Attribute Validator get rules from table
Related products:Transformers
  • January 31, 2018
  • 6 replies
  • 110 views
jpvo
Like the SchemaMapper which takes mapping rules from external file, the AttributeValidator could read validation rules from a table.
This would also allow validation rules maintenance by non FME people.
navaneet
This will be nice.
Forum|alt.badge.img+54
  • February 21, 2020
To add to this, include an option to give a rule a name which is then reported in the fme_validation_message
antoine
Forum|alt.badge.img+7
  • June 3, 2021
Any news from Safe on this? It forces us to use other tools or attributeexploser with a tester to use external rules.
ltwigg
Forum|alt.badge.img+3
  • December 5, 2022
I've built a BulkAttributeValidatorWithMapping, takes external configuration file like SchemaMapper, allows logical testing like Tester (including NOT), can group tests together (eg "Attribute A is a number, or Attribute A is blank"; or... "Attribute A is ABC or Attribute B is DEF"), and custom error messages can be entered (each failed test is concatenated onto an error string). It works with un-exposed attributes (designed to work with an upstream SchemaMapper). May take a while to run as it checks each feature against each validation rule.
If anyone is still following this thread and is interested, I'd appreciate any feedback.
LizAtSafe
Forum|alt.badge.img+25
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
