Released
Async HTTPCaller
Related products:FME Form
  • Apr 26, 2018 12:00 AM UTC
  • 5 replies
  • 152 views
paalped
Forum|alt.badge.img+11
I want the HTTPCaller to support async get requests. This could really increase the perfomance of HTTPCaller. Now HTTPCaller wait for every request to come back before it fetches the next request, this is a big waste of resources, the program is basically in idle until it recieves its request.
A naive look into async:
You need to get multiple get requests, so instead of sending a request, getting answer for the request, send a new request, get the answer of the new request and so on. the program would quickly send all requests in a loop without waiting, and then start to recieve requests as the come back in a unordered sequence.
jdh
Forum|alt.badge.img+41
  • Nov 8, 2018 9:42 PM UTC
I would like to see this with a parameter controlling the number of simultaneous requests. I don't want to hammer a server, but when it accepts 4-6 simultaneous connections from a single IP address, I would like to take advantage of that fact easily.
My current workaround is to put the HTTPCaller in a custom transformer, place a modulo counter just before the CT with the count set to the number of concurrent connections and enable parallel processing with the group by set to the modulo attribute.
I am encountering the same query from other FME users in my office. You wouldn't happen to have the custom transformer available to share?
jdh
  • Mar 26, 2019 1:49 PM UTC
Unfortunately not, but the only thing in the custom transformer is the HTTPCaller.
paalped
  • Jan 14, 2020 1:22 PM UTC
Hi @jasonclemis,
I have now explored the asyncio in FME 2019 With Python 3.7. and its quite easy to do Async get requests With the improved features of 3.7. Are you still interested in this? I can try to bundle it inside a Custom Transfomer.
siennaatsafe
Forum|alt.badge.img+12
Update, May 18th, 2021! This functionality has now been released in FME 2021.0 https://community.safe.com/s/idea/0874Q000000TkurQAC/detail
See Concurrency / Looping Options in our HTTPCaller Documentation
