Open
Add 'ON_ERROR' option settings to SnowFlake writer
Related products:Integrations
martinkoch
Forum|alt.badge.img+25
I have been using the SnowFlake (spatial) writer now for some projects, and experience Snowflake to be quite picky when it comes to the geography it accepts...
Not particular Safe Softwares problem, but while struggling I often enountered
If you would like to continue loading when an error is encountered, use other values such as 'SKIP_FILE' or 'CONTINUE' for the ON_ERROR option. For more information on loading options, please run 'info loading_data' in a SQL client.
after the error message generated by the copy-command (copy-ing the contence of a .gz file to the table).
Could I please have some way of setting these ON_ERROR flags in the snowflake writer? Ofcourse aware of possible data corruption, I still would like them, if even only for debugging...
Kind regards,
Martin
