Open
Add a Sampler option to drop unsampled data
Related products:Transformers
  • November 20, 2024
  • 7 replies
  • 138 views
landersen
  • landersen
    landersen
mark2atsafe
I wondered, maybe Safe could add an option to the Sampler to drop unsampled data, instead of sending it out of the unsampled port.
Why?
Because when I run a workspace with caching turned on, it’s using up resources caching unsampled data that I don’t need.
This is especially true since I was set up to sample only the first feature. Having obtained that single feature, I really don’t need the Sampler to carry on storing other data. In fact, I don’t really need it to carry on processing at all!
liamfez
Forum|alt.badge.img+34
  • November 20, 2024
This is a good idea, I also frequently use the sampler in the same way. Perhaps a feature caching update could include both this idea and the Bookmark Feature Cache Switch idea.
johnt
Forum|alt.badge.img+11
  • November 21, 2024
I'm sure I had a similar idea in the previous website, but a switch on all output ports of all transformers. Then you can choose any output ports where droppage of features is OK/expected whilst developing a workspace
Forum|alt.badge.img+38
  • November 21, 2024
I’d prefer an option to stop upstream processing when the sampler has passed the required number of features. At the moment I can wrap everything in a bookmark and collapse it to avoid caching but there’s often still a lot of processing time upstream waiting for all features to reach the sampler.
matthieuv
Forum|alt.badge.img+20
  • November 21, 2024
A workaround for now could be to put the sampler in a collapsed bookmark. Then only the output is cached and the non sampled port not connected to anything will be dropped.
mark2atsafe
Forum|alt.badge.img+44
  • November 22, 2024
I was thinking about whether the Tester:Failed port could get the same behaviour, but as a couple of people mentioned, why not a switch for all output ports? That would be really useful! Of course, I always try to consider whether a smaller request is more likely to get done than a larger one. The bigger the request, the more we have to justify it.
LizAtSafe
Forum|alt.badge.img+15
  • November 28, 2024
NewOpen
LizAtSafe
  • April 5, 2025
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
