Open
Update all available Coordinate Systems with EPSG Codes
Related products:Transformers
  • December 18, 2022
  • 132 views
danilo_fme
tcrossman
oscard
gisbradokla
fgiron
+9
  • danilo_fme
    danilo_fme
  • tcrossman
    tcrossman
  • oscard
    oscard
  • gisbradokla
    gisbradokla
  • fgiron
    fgiron
  • mattwilkie
    mattwilkie
  • nic_ran
    nic_ran
  • mgg_beca
    mgg_beca
  • philsc
    philsc
  • jorge_rosales
    jorge_rosales
  • icova
    icova
  • yansa
    yansa
  • ardadurmus
    ardadurmus
  • gbenayas
    gbenayas
mgg_beca
Hi there,
Depending upon their source Coordinate Systems in FME may or may not have EPSG codes matched to them.
For example if our user picks NZGD2K.MountEden from the list I can use the CoordinateSystemDescriptionConverter transformer to extract the EPSG code and use it in the workspace. However if they choose MOUNT_EDEN_2000 then there is no EPSG code associated with it and the CoordinateSystemDescriptionConverter returns nothing.
Would it be possible to sync the various coordinate systems so that all available information is available to FME no mater which CS version they choose? I am not able to limit the end users choice in the Server app as I need to cater for all possible coordinate systems.
I understand the different coordinate systems have different "metadata" with them, depending upon their source, however this can lead to an inconsistent experience for the end user.
Regards,
Marc
mattwilkie
Forum|alt.badge.img+11
  • February 13, 2025
Awhile ago ​@daveatsafe suggested I use the PROJReprojector, and today I’ve finally come back around to this issue and confirmed: it works with all EPSG codes I need. Reading through it’s doc page, the transformer should work for most anyone else too since it’s using PROJ Library 9.5.0, which is up to Sept 2024.
mattwilkie
  • February 17, 2025
Warning: there’s a serious bug in some versions of PROJReprojector in FME Desktop (Form) - trying to type in the [destination coordinate system] field instead of using the drop down picker will induce a freeze and rapid memory leak, leading to a hard FME crash.
Update your FME to FME 2024.1.1.1 or higher to remove the problem. You can download the latest FME from safe.com/download.
