Open
Unleashing the power of variables!
Related products:Transformers
  • December 16, 2019
  • 5 replies
  • 46 views
  • siennaatsafe
    siennaatsafe
  • david_r
  • revesz
    revesz
  • gistack
  • wicki
    wicki
bo
A parameter is like an argument that is static. A variable, however, represents a state and can be dynamically created and assigned in a workspace. I wish FME workspace UI exposes variables the same way it exposes parameters or attributes. Converting variables to attributes via VariableRetriever does not help, as attributes are about content while variables are about states and flow control.
I am in agreement with @bambography in his or her post.
https://knowledge.safe.com/questions/34563/can-global-variables-be-accessed-as-values-in-tran.html
  • December 16, 2019
I agree, there needs to be better support for using variables without using dedicated transformers (VariableSetter / VariableRetriever). My preference would be to add the following:
Function call, e.g.
@Variable(_my_variable)
Python API, e.g.
value = fmeobjects.FMESession().getVariable('_my_variable') fmeobjects.FMESession().setVariable('_my_variable', 'My Value')
jdh
Forum|alt.badge.img+28
  • December 16, 2019
At the very least the VariableRetriever should be a dropdown list of all the variable names used in a variableSetter.
virtualcitymatt
Forum|alt.badge.img+36
Oh yes this would make things a lot easier. I would love to use a tester based on the value of a variable in the same way. Having to retrieve the variable as an attribute and then test is a real pain.
Also not being able to retrieve multiple variables with one VariableRetriever is another pet peeve (https://community.safe.com/s/idea/0874Q000000TlDuQAK/detail) also https://community.safe.com/s/idea/0874Q000000TkzIQAS/detail
Also what David said!
LizAtSafe
Forum|alt.badge.img+15
  • October 29, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • April 5, 2025
