Archived
Support for reading Civil3D Surfaces
Related products:FME Form
brianatsafe
hkingsbury
danilo_fme
dustin
+3
  • brianatsafe
    brianatsafe
  • david_r
  • hkingsbury
    hkingsbury
  • danilo_fme
    danilo_fme
  • dustin
    dustin
  • bruceharold
    bruceharold
  • thaverkort
    thaverkort
  • mark2atsafe
    mark2atsafe
FME is currently unable to read Civil3D surfaces directly from the Civil3D dwg file. I have posted my workaround HERE but it is not perfect and requires too much pre-processing before you can read in FME. Also, you would have to remember to repeat those steps every time the source surface changes. I've also experimented with a workspace to derive the boundaries from the LandXML file, instead of one extracted in Civil3D, then trim the surface to those boundaries. But it only works if a boundary was input in Civil3D, still not perfect and still requires a LandXML file be created after every surface change.
