Archived
Read AutoCad Extended Data Documentation Attributes
danilo_fme
  • danilo_fme
    danilo_fme
fmelizard
Add Support for reading AutoCad Extended Data Documentation attributes such as "Notes", "Hyperlink", and "Reference Documents".
The ability to read Custom (as opposed to General or Summary) DWG file properties would be extremely useful. It appears the only way to extract file properties from a DWG file without first starting AutoCAD or the AutoCAD Core Console is to use the RealDWG SDK (which is a separately licensed product).
jneujens
  • September 8, 2017
Certainly for other documents in xref, that would be very useful!
