Archived
ArcGIS MXD Metadata Read/Write
Related products:Integrations
k_murai
bryanmayor
danilo_fme
+3
  • k_murai
    k_murai
  • bryanmayor
    bryanmayor
  • redgeographics
  • takashi
  • danilo_fme
    danilo_fme
  • tomfriedl
    tomfriedl
  • philippeb
    philippeb
  • DanAtSafe
    DanAtSafe
fmelizard
The reader would return all the metadata descriptions of the layers defined in a .mxd file, and the writer would take this information and create a .mxd file. ArcObjects would have to be available for this to work. Would provide for bulk operations on .mxd files, as well as creation of .mxd files in the same process as geodatabases or shape files were being created.
geckosolutions
Forum|alt.badge.img+4
This would be really useful for my specific use cases as I have a lot of MXD's that are pretty formulaic and could be controlled via a spreadsheet and generated on the fly to the benefit of my users. A user in a large corporation can log in and see a newly generated MXD for them to browse the data and it will contain all the latest layers, labeling, formatting, etc..
ekkischeffler
Forum|alt.badge.img+5
Great idea. This would be useful for creating map outputs. So having the option to use MXD templates in both an MXD and a PDF writer would be perfect.
  • April 23, 2016
Had a request for this during FMEWT
nathanatsafe
Forum|alt.badge.img+7
This might be a good option for a hub transformer as functions for this exist in ArcPy.
bark0s
Forum|alt.badge.img+3
  • February 7, 2019
If it could delve into Grouped layers at the same time, that'd be even better.
chriswilson
Forum|alt.badge.img+11
  • August 8, 2019
Could ArcGIS Pro projects be included in this? Since one day they will be the default rather than MXDs.
bruceharold
Forum|alt.badge.img+17
  • August 9, 2019
@fmelizard How about making this idea "Create a Web Map Reader & Writer" so that you're not limited to ArcMap going in and coming out?
https://developers.arcgis.com/web-map-specification/
ce
  • August 8, 2021
Being able to extract the layer names from an mxd would be fantastic! Being able to dig a bit deeper and get the data source name would complete what it going to be a tedious manual task.
sheree
  • March 15, 2022
Having an MXD Reader/ writer would benefit us with GDA 2020 conversion instead of having to run python scripts over mxds, a tedious task this will be
  • January 9, 2023
2023 bump.
Yes please on .mxd reader / writer.
stewartatsafe
ESRI are moving away from MXD, here is the issue tracking APRX supoport.
