Open
Add filter function to the table view in FME Data inspector
Related products:FME Form
  • November 18, 2015
  • 13 views
taojunabc
Participant
FME Data inspector have a function of Filter Features,But it seems to work only on Feature View,and not on Table View.Most of the time, filtering the features, but also hope that the Table View can keep synchronized,If this function can work both on the Feature View and Table View,It may be more convenient.
fgiron
Forum|alt.badge.img+21
  • February 29, 2016
Well, you can also filter the table view separately, but it would make sense to me if the filter you make in one side goes together with the other side, or at least having the option of doing so
mhab
Forum|alt.badge.img+10
  • June 1, 2017
I would appreciate that Filter also works on table view. Currently (FME 2017) it is possible to select/mark selected records within table view, but not to limit the view to filtered records/features.
I feel it is a bit inconsistent if filter doesn't work on this window.
It is also important that after the features are filtered, the associated filtered records in the table view become easily found or brought to the top of records in the table.
