Archived
Update publish parameter values in bulk at workspace publish time
Related products:FME Form
fmelizard
As an FME Server user, when I update the default values for Published Parameters in workbench, I would like an easy solution to apply these changes to all the functions that use this workspace when I re-publish it to FME Server i.e. schedules and workspace subscribers.
I suggest adding a checkbox option within the publishing wizard in FME Workbench, which list all scenarios where this workspace is run that were created by my user account so that I can choose which ones should be updated with the new default values at publishing time.
LizAtSafe
Forum|alt.badge.img+15
  • February 10, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
