Open
Set all user parameter values to default or clear at once
Related products:FME Form
  • February 28, 2019
  • 9 replies
  • 244 views
g_karssenberg
Forum|alt.badge.img+7
During workspace testing I often use a lot of different parameter values. When I have a certain version ready for deployment or a next iteration, I would like to (re)set all the parameter values at once. This could be to the parameter default values or clear all values.
My suggestion is to add to the Navigator pane:
  • User Parameters (root)
  • Published Parameters (sub)
  • Private Parameters (sub)
  • FME Server Parameters (sub)
right mouse click options:
  • Set all parameter values to Default
  • Clear all parameter values
  • February 28, 2019
Great idea.
g_karssenberg
  • May 3, 2019
Also very convenient to be able to do this before (re)publishing to FME Server.
Forum|alt.badge.img+62
I agree, especially on the part before publishing to Server (maybe that could be an option in the publishing process: "do you want to reset all parameters?"
jdh
Forum|alt.badge.img+40
  • May 3, 2019
The number of times I've published to server with a 'default' value set to my test data ....
g_karssenberg
  • November 13, 2019
Yes, that would come in handy. However, sometimes not all parameters need to be reset. If you want to use a default value for a parameter, that one should not be cleared. So maybe a parameter list with check boxes to check the ones you want to clear would be an idea.
stevenjh
Forum|alt.badge.img+5
  • April 6, 2022
I'm reading this as an easy way to switch parameters as a 'set', quickly change a bunch of params between dev/test/prod. It would be a great addition!
LizAtSafe
Forum|alt.badge.img+18
  • February 10, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • February 10, 2024
chriswilson
Forum|alt.badge.img+21
  • November 25, 2025
Having created a long form for Flow I now realise I also would like this!
