Open
Feature cache force run to/from this
Related products:FME Form
giapan85
mkludas
benzc
siennaatsafe
+26
  • flansch
  • giapan85
    giapan85
  • mkludas
    mkludas
  • benzc
    benzc
  • siennaatsafe
    siennaatsafe
  • ebygomm
  • tcrossman
    tcrossman
  • tomf
    tomf
  • mattwilkie
    mattwilkie
  • nic_ran
    nic_ran
  • jelle
    jelle
  • alexlynch3450
    alexlynch3450
  • kennyo
    kennyo
  • jackyd
    jackyd
  • albinepro
    albinepro
  • spatialexjames
    spatialexjames
  • josephcannonecc
  • lillarcor
    lillarcor
  • paulbrandtkcs
  • brendanneal
    brendanneal
  • lindsay
    lindsay
  • bigclyde
    bigclyde
  • marcoroose
    marcoroose
  • mvanwie
    mvanwie
  • andre.utilit
  • mmccart
    mmccart
  • asablomberg
    asablomberg
  • tim.albert.vaa
    tim.albert.vaa
  • janrykr
    janrykr
  • padrigue
  • chambleegis
    chambleegis
nic_ran
It would be great if the "Run to this" / "Run from this" options within a workspace could be extended to have a "force run" or "rerun" option. Feature caching is fairly smart and will re-run stale caches when required. The problem is when an underlying dataset has changed and the feature caches aren't aware.
For example, when using a FeatureReader or DatabaseJoiner, the underlying data may have changed and, currently, the only way to get the workspace to pick this up is to either re-run the entire workspace, or make a temporary edit in the workspace that causes the cached data to become stale.
Another scenario in which this is an issue is if a custom transformer is updated, then the main workspace feature caches do not account for this unless the custom transformer interface changes.
nic_ran
Forum|alt.badge.img+16
  • April 27, 2020
I found another "Idea" after I posted this one. Seems to be an alternative solution to the same underlying problem..
https://knowledge.safe.com/idea/94922/empty-feature-cashing.html
pmcpherson
Forum|alt.badge.img+9
  • January 11, 2021
Not sure of the status of this idea, but I too have run into a similar issue many times. It would be nice to have a bit more flexibility with regard to clearing the feature cache(s) without rerunning the entire workspace.
tomf
Forum|alt.badge.img+14
  • January 14, 2021
Have you tried Tools > Purge Temporary Files? This should clear the cache for you
