web application interface is slow
  • Jul 27, 2022 4:38 PM UTC
  • 65 views
We operate currently the FME Server 2022.0.0.2 on the Windows Server 2022 Standart platform
Compared to FME Cloud is web application interface slower.
This mainly concerns the entry of files in "Published Parameters" when starting the application from the gallery (or directly starting the workbench),
when after dragging the file, it is loaded according to the 100% indicator, but then it takes up to several seconds before the actual file name is displayed.
We used chrome verse 103.0.5060.134
Don't know what the problem could be?
Thank you for answer.
skime
  • Feb 17, 2023 12:49 PM UTC
Did you try to change disk where FME Server files are to SSD one? This may be the cause of slow web UI.
