Use FME Server REST API to query failed jobs in last n days/hours/minutes
  • Oct 14, 2020 4:31 PM UTC
  • 5 replies
  • 220 views
john_gis4
Forum|alt.badge.img+13
Hi
I'm looking at ways to monitor FME Server using the REST API and would like to perhaps query for all failed jobs in the last n days/hours/minutes.
I can see it's possible with the V3 API to query for failed jobs - e.g.
https://myfmeserver/fmerest/v3/transformations/jobs/completed?completedState=failed
However, this will return all failed jobs. If we are monitoring for recent failures, we would want to query using dates or a timeframe. Is this currently possible?
Thanks
John
Hi @john_gis4bus​ ,
It is not currently possible to query this endpoint by date. This is a great suggestion, our team is currently working on Rest API V4 so I have passed this request on to our product owner. I'd also recommend you create an idea to request this support.
For now, you'd need to perform a filter on the result using the timeFinished attribute.
itsmatt
Forum|alt.badge.img+48
  • Oct 14, 2020 6:24 PM UTC
We've set up a daily schedule to migrate job history into a postgres table, a bit of duplication, however, when updating to a new version of FME Server it lets us keep all the history - Makes it easy to query the data with SQL. The FME Server database should also have this available to query directly.
If you wanted to do this web based via REST you could just create a workspace which queries the database and returns what you want between two given dates. Its a little more than a simple rest call, but it could be a way...
john_gis4
  • Oct 15, 2020 9:06 AM UTC
Thanks @virtualcitymatt​ for those workarounds. Quering the FME Server DB directly could be the way forward I think.
john_gis4
  • Oct 15, 2020 9:07 AM UTC
Hi @john_gis4bus​ ,
Thanks for confirming @hollyatsafe​ - I will certainly create an idea for this support.
john_gis4
  • Oct 15, 2020 9:14 AM UTC
