Unable to access FME Web Interface from any machine other than the server itself
  • Sep 2, 2021 10:50 PM UTC
  • 7 replies
  • 328 views
Hi all, we've just installed FME server, on a standalone machine. All components on one server. We are able to access the fme web interface from the server itself (it's configured for https) and all looks great. However we're unable to access the site from any workstations. Our network team says they have allowed traffic through port 443 (https) so we should be ok there. When trying to load the site on Chrome, we get the following error: The Site can't be reached.... took to long to respond....ERR_CONNECTION_TIMED_OUT. Any thoughts? Not sure what else to try at this point. Our network team is still working on this, and trying to determine where the traffic is being blocked but thought I'd see if anyone else has had this issue. Is 443 the only port needed to be open in this case? -Thanks in advance.
Best answer by david_r
If you've properly configured FME Server with SSL, opening port 443 should suffice.
However, the error message makes me think that there's an issue with a firewall somewhere, but of course there could be a number of other issues as well. Can you ping the server? How about doing a traceroute?
hkingsbury
Forum|alt.badge.img+73
  • Sep 2, 2021 10:57 PM UTC
Just checking you've worked your way through this - specifically the part about change the tomcat config files?
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/configuring_for_https.htm
  • Sep 2, 2021 11:04 PM UTC
Yes, I did make sure to update the tomcat config files and restarted the FME server as well. Get Outlook for iOS
hkingsbury
  • Sep 2, 2021 11:45 PM UTC
are you going through IIS, or connecting straight to tomcat?
  • Sep 3, 2021 12:14 AM UTC
Straight through tomcat. No IIS involved. Get Outlook for iOS
  • Sep 3, 2021 6:29 AM UTC
Forum|alt.badge.img+63
Here's the relevant FME Server Troubleshooting guide.
  • Sep 3, 2021 3:40 PM UTC
Thank you all for the great feedback! We are up and running now. It appears that we either just needed some time for the firewall rules to propagate, or the final fme restart I did last night did the trick. Either way, we're up and running now. We only did need port 443 like was mentioned, and the configuration was ok. So I'm assuming it was just the firewall rules, or the network routing that needed to get worked out. Thanks again all, I didn't expect so many answers so fast. Great community here!
