Two FME server VMs in azure throwing authentication error while accessing the fme server url
  • Jan 10, 2023 12:38 PM UTC
  • 40 views
swethabhupathi
Forum|alt.badge.img+5
We have two FME machines (FME1 & FME2) hosted in azure and is been accessed via a DNS name URL (e.g. fme.domain.com).
Issue: If both the VMs are running, the the fme server URL is throwing authentication error and not allowing us to login. If one of the machines (anyone) is removed from azure, then the FME URL is launching fine.
What could be the reason?
From our initial investigation, we found that the machine keys of both the machines are different, but the serial numbers are same.
richardatsafe
Forum|alt.badge.img+11
Hi @swethabhupathi​ ,
Unfortunately, I've never seen this issue before. Could you provide some background on what you are trying to install?
-Is this a fault-tolerant installation or are the two installations completely unrelated?
-When you installed did you use the hostname of the machine or IP as the Server name?
-Do you have an example of the Authentication issue? Is it an LDAP or SAML authentication problem or is the authentication issue presenting itself in a different way?
