remove a string from WebSocket
  • Mar 5, 2023 8:54 AM UTC
  • 46 views
boubcher
Forum|alt.badge.img+11
Hello There
I am using FME to generate a WebSocket stream, on the desktop we are getting the valid JSON format, but when published to the server I am getting an extract Caracter ( " \\") backslash
{ "ws_publisher_content": "{ \\"type\\" : \\"FeatureCollection\\", \\"Features\\" : [ { \\"type\\" : \\"Features\\", \\"geometry\\" : { \\"type\\" : \\"Point\\", \\"coordinates\\" : [ 48.740187789955101, 27.965531016954699 ] }, \\"properties\\" : { \\"truck_plate\\" : \\"YHSR2379\\", \\"latitude\\" : 27.965531016954699, \\"longitude\\" : 48.740187789955101, \\"event_type\\" : null, \\"event_color\\" : null, \\"severity\\" : null, \\"status\\" : \\"On_Road\\", \\"counter\\" : 1562, \\"time_stampe\\" : 20230115061550 } } ] }", "ws_topic": "esr_geoevent_demo", "fns_type": "ws_publisher" }
the app consuming this web socket will not accept this structure
Thanks
siennaatsafe
Forum|alt.badge.img+12
Hi @boubcher​ ,
Sorry, you are encountering this issue. I tried to reproduce it but have been unable to so far. Would you mind sharing your workspace? If you can't share the entire workspace, just the WebSocket Sender would be fine, if I can take a look at the JSON produced. Also, how are you viewing the WebSocket stream? Is it on FME Server or another tool?
