Geometry Picker - Draw Point instead of polygon or rectangle
  • September 20, 2022
  • 5 replies
  • 296 views
llgis
I want to calculate a buffer around a point using the geometry picker in fme server. Can I use the geometry picker to select/draw a point instead of a polygon or rectangle? :)
Best answer by keziaatsafe
Hi @llgis​ ,
What version of FME Server are you using? If you open your workspace in FME Workbench, you should be able to edit the User Parameter- Geometry Picker to enable Point Geometry type. In your current screenshot there is no option for Point type, however once you change the user parameter and republish to FME Server, you should see the marker option to select a point on the map.
UserParameterMarker
Hope this helps!
Kezia
keziaatsafe
Forum|alt.badge.img+7
Hi @llgis​ ,
UserParameterMarker
Hope this helps!
Kezia
llgis
  • September 21, 2022
Thank you! Works great in FME Server 2022.1.2
timwarfe
  • January 12, 2023
Can you make multiple pinpoints using the Geometry Picker in one request and bring back the results relating to those points? Server 2022.2
richardatsafe
Forum|alt.badge.img+10
Hi @Tim Warfe​ ,
Unfortunately not, but if you want to upvote the idea of multiple features in the Geometry Picker that would help the enhancement.
timwarfe
  • January 16, 2023
richardatsafe wrote:
Hi @Tim Warfe​ ,
Thank you, Richard. I've voted for that feature idea. :)
