FME Server Email Authentication OAUTH
  • November 14, 2022
  • 150 views
warrendev
Forum|alt.badge.img+23
We recently upgraded to FME Server 2022.2 and were having issues adding an emailer to an FME Automation. After inserting an emailer within an Automation, we are receiving an error when attempting to validate the email after putting in the Client ID of the app registration that we created within Azure Active Directory App Registration.
We are receiving this error when validating:
fme_error
Is there a walkthrough going over the new Microsoft Office365 email authentication within FME Server? I see the FME Desktop emailer has been updated to use a web connection, and I'm able to successfully create this web connection and send an email, but still having issues within FME Server email automation.
Best answer by warrendev
Hi @keziaatsafe,
I did have the setting to allow public client flows, but I had forgot to add the permission for SMTP. After adding that permission, and IMAP for email polling, everything works great! Thanks for the help.
keziaatsafe
Forum|alt.badge.img+7
  • November 16, 2022
Hi @Chris Warren​ ,
Can you try changing this setting in your Azure App and see if it works after?
https://stackoverflow.com/questions/45609432/how-do-i-resolve-the-error-aadsts7000218-the-request-body-must-contain-the-foll
Or please find and modify a setting called “allow public client flows” to Yes, this should restored your ability for Server to retrieve the emails via IMAP.
Hope this helps!
Kezia
warrendev
  • November 18, 2022
Hi @keziaatsafe,
