Hi all!
I have created a FME Workflow in Desktop which connects and runs fine. I then published the workflow to Server and immediately ran the workflow again for it to work fine...for a short while. After some time, the workflow begins to fail with a '401 - Not Authenticated' error.
If I go into Web Connections on FME Server and 'Authorise' the Web Connection, I can enter my Sharepoint username and password before approving the permissions. The next screen then appears totally blank. Behind the scenes, Sharepoint is returning the following error; 'the endpoint only accepts POST requests. Received a GET request.”'
I've read and followed this article but to no avail; 'Sharepointonline connector - configuration for FME Server 2019.0 (safe.com)'.
Any assistance would be warmly welcomed before I pull my remaining hair out!
Thanks,
Sean
