FME Server 2022.2 - problem updating upload files
  • Oct 18, 2023 9:25 AM UTC
  • 165 views
ronan
Hello,
We have updated FME Server from 2020 to 2022.2. Then there is something wrong with the upload files :
  • We publish into FMEServer a workbench containing a "File/URL" User parameter
  • Then we RUN the workspace 2 times : The file we upload has the same name, but the content of these 2 files is different
--> FME Server doesn't update the file located here : FME Server\\SystemShare\\resources\\system\\temp\\upload\\ if we don't purge the folder (In case we change the file name, it works well.)
We have not encountered this problem with FME 2020.2
Can anyone help?
Thank you
Ronan
merlinegeorge
Hello,
This could be a 2022.2.4 bug where there was an issue with Data Upload Service when a file of the same name was uploaded using the Web UI on the Job Submitter page. The upload service when running a workspace, had a source dataset parameter[ In that case, the file format was .csv] .
This issue occurs when the user uploads a file of the same name. A .tmp file is created in the /Resouces/system/temp/upload when the user uploads the file, indicating the file is uploaded correctly. However, the temp folder <repository>/<workspace> which is created to hold the temp upload does not clean up and can’t be replaced when a new file is uploaded. This has been fixed in 2023.0
and 2023.1. The workaround for this issue is to run a temp cleanup system event to get rid of the old file.
How is this job running on FME Server- via automation, workspace app or manually on run workspace page ?
If this is not helpful, would you be able to create a case with the following information-
  • Job logs for the two job runs
  • The workspace file
ronan
  • Oct 24, 2023 11:42 AM UTC
Hello,
Hello,
Thanks a lot for your answer.
The bug you describe is exactly what happen. I have checked directly in the folder /Resouces/system/temp/upload and the file doesn't update when the user uploads a file with the same name. I encountered the problem with 2 completely different workspaces.
In each case, we use a workspace app.
- I understand that the solution you suggest is to use a temp cleanup system event to get rid of the old files/subfolder of this folder : \\FME Server\\SystemShare\\resources\\system\\temp\\upload : Do you mean the solution would be to increase the frequency of : System configuration --> system cleanup --> Delete_dataUpload_File task? Couldn't there be a side effect if the cleaning process is carried out while another job is running?
- Sometimes, the users perform the same workspace twice at 3 minutes intervals. The upload file name is the same, the content is different : using the schedule to launch a cleaning process does not seem to be a perfect solution, it would then be necessary to run the process every 2 minutes to prevent the bug? Are maybe can we perform the process after a trigger? Is there a trigger like: after such worskpace is finished?
- Is it possible to directly apply a patch to the FME server 2022.2 installed in our environment to resolve the problem at the roots?
