Error message in web interface of FME Server
stalknecht
Forum|alt.badge.img+19
If I look at the web interface I receive errors.
Error: Error communicating with FME Server. FME Server may not be running. Contact your FME Server administrator who can investigate the log files for further details.Connection refused: connect.
Does anyone know what the source of these messages are?
  • March 30, 2016
Hi
Check that all the FME Server services are up and running:
  • FME License Server
  • FME Server Application Server
  • FME Server Core
  • FME Server Database
  • FME Server Engines
  • FME Server SMTP relay (optional)
David
stalknecht
  • March 30, 2016
david_r wrote:
Hi
  • FME Server Core
David
They are all running! Reboot, Restart doesn't help
  • March 30, 2016
If all the services are running, you should probably check the FME Server logs for errors.
Try looking under Manage / Resources / Logs, in particular in core / current / xxx_fmeserver.log
mark2atsafe
Forum|alt.badge.img+44
  • March 30, 2016
Could be a timeout. Does it take a long time or a short time to return that error? Also, what web browser are you using? Do you get a different result with a different browser?
stalknecht
  • March 30, 2016
It takes less then a second that the message appears on the Engine Management page.Tried the latest version of Chrome, Edge and IE same result.
mark2atsafe
  • March 30, 2016
Then I'm afraid it's beyond me. If the log files don't provide any clues I would contact your local reseller support or the Safe support team (http://safe.com/support)
