Enabling "Resource" tab in workspace application.
brendanneal
How do you enable "Resources" tab within workspace application?
If I run my workspace in FME Server and want to input source file > Browse Resources.
FMEServerWorkspaceResourcesTabI get the Resources tab (highlighted in Yellow)
I have created a workspace application and when you select > Browse Resources. I don't get the "Resources" tab in the application?
FMEServerWorkspaceAppNOResourcesTab
I'm pretty sure it probably has something to do with how the Resources are shared in FME Server, I have pretty much shared I believe out to everyone in FME Server. Example of resource sharing below:
FMEServerResourceSharing
Pretty new to FME Server so I'm sure it is a very easy change.
Thanks in advance
Brendan
Best answer by keziaatsafe
Hi @brendanneal​ ,
You will need to add extra permissions to your workspace app token.
Edit your workspace app and once it has been saved, select Add More Permissions.
WorkspaceAppExtraPermissionsThis will take you to the Editing API token for your workspace app. Scroll down to the Resources Permissions and click the down arrow to expand the folders. Select the appropriate level of access to the Data folder that you would like to provide for your users.
TokenResourcesPermissions
Hope this helps!
Kezia
keziaatsafe
Forum|alt.badge.img+7
  • April 6, 2022
Hi @brendanneal​ ,
Hope this helps!
Kezia
brendanneal
  • April 6, 2022
keziaatsafe wrote:
Hi @brendanneal​ ,
Hope this helps!
Kezia
Perfect!! Thank you very much.
