Distributed Engine Host not visible from the Web UI
  • Jan 14, 2021 12:11 PM UTC
  • 107 views
knutos
Forum|alt.badge.img+8
I am struggling with an Express with a Distributed Engine installation, see this article: https://community.safe.com/s/article/separate-engine-installation. All steps in the documentation and this article have been followed carefully. The core machine is running as it should, and so is the FME Engine service on the distributed engine machine.
Unfortunately, the Distributed Engine Host does not appear in the Hosts list under Licensing & Engines/Engines page in the WebUI. What could possibly be wrong?
richardatsafe
Forum|alt.badge.img+11
Hi @knutos​ ,
If all the steps have been confirmed in our current documentation for a distributed engine installation and the engine is running. Then it might be a port issue please ensure that all these ports are open between the machines.
You can also check the logs files for information. Both the fmeserver.log on the core machine and the fmeprocessmonitorcore.log and on the engine machine, fmeprocessmonitorengine.log. These logs can have warning that can highlight the issue.
