Connection to FME Server Bash
Is there a way to connect to the bash of the Fme Server from the cloud?
I want to install a couple custom Linux packages from the command line, like Wine, Docker, GCC, is that possible?
Forum|alt.badge.img+58
Do you mean on FME Cloud? That's not possible, those machines can only be accessed through the web interface.
If its your own FME Server installation (that just happens to be in the cloud) then yes, but you should talk to the admin about that.
  • February 17, 2022
Thank you for the answer!
