configuring FME server with Azure AD
  • Aug 17, 2022 2:37 PM UTC
  • 107 views
heinderooij
we have make an app registration in azure by following this article:
Configuring Azure Active Directory with FME Server (safe.com)
I filled the tenant en client id etc from azure application to the server by new azure active directory but nothing happends after synchronizing.
must we make an enterprise appliaction ( so it says on fke server "Before you begin...") in stead off an app application? where can we link the ad groups in azure ?
merlinegeorge
Hello @heinderooij​ ,
Per our documentation, in order for FME Server to communicate with Azure AD, you must create and register FME Server as an enterprise application in Azure AD.
In case of issues, please check the fmeserver.log file [located at <FMEServerFileShare>\\resources\\logs\\core\\current] for any error message related to Directory services.
Once you successfully create the Azure connection, you should be able to import the Azure groups from the Web UI -image
heinderooij
  • Aug 24, 2022 7:58 AM UTC
thanks for yor answer. I'll make an enterprise app 😀
