Async jobs don't notify when failing because of invalid parameters
  • November 8, 2022
  • 7 views
aegman
Forum|alt.badge.img+3
Is there a way to get FME Server to notify a topic when a job fails to start from the queue because of invalid or missing parameters?
We submit an async job, which returns 202 and a job number. It sits in the queue for a while, and then fails when it comes up to be run.
Submitting sync jobs with invalid parameters return a 422 immediately, along with an error message.
The job doesn't run, so doesn't trigger start/stop scripts, and doesn't appear to notify the Failure topic either.
I've been searching around for a while but haven't found anything helpful yet.
Thanks,
Andy
siennaatsafe
Forum|alt.badge.img+11
Hi @Andy E​ ,
I tried testing this out on a 2022.2 server and I believe everything is working okay.
From the REST Call, I didn't provide the necessary parameters but provided a failure topic.
2022-11-10_15-23-14The failure topic was triggered.
2022-11-10_15-25-40
What version are you using?
