xml to point
  • May 15, 2023 8:36 AM UTC
  • 5 replies
  • 152 views
bayram
Forum|alt.badge.img+7
Hello everyone
I have coordinate values in xml data. I want to generate points from these values. I tried some methods but failed. Can you help me?
Best answer by nielsgerrits
merhaba nielsgerrits
Thank you very much for your answer, I followed the steps, but I could not reach the result, if possible and if you have time, can you make a WB? My xml file is attached
Nothing beats a working example :) happy I could help.
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use a XMLFragmenter to create features from the objects with lat/lon in it.
  • Creater to initiate.
  • XMLFragmenter
    • Elements to match
      • PreviousRecordingData/Markers/Marker
      • PreviousRecordingData/Recordings/PreviousRecording
    • Merge Attributes From Input Feature
      • No
    • Flatten Options
      • Enable Flattening
  • AttributeExposer
    • Latitude
    • Longitude
  • VertexCreator
    • X = Longitude
    • Y = Latitude
  • CoordinateSystemSetter
    • EPSG:4326
bayram
  • May 15, 2023 10:34 AM UTC
  • XMLFragmenter
    • Elements to match
      • No
    • Flatten Options
      • Enable Flattening
  • AttributeExposer
    • Latitude
    • Longitude
  • VertexCreator
    • X = Longitude
    • Y = Latitude
    • EPSG:4326
nielsgerrits
Sure :)
bayram
  • May 16, 2023 8:37 AM UTC
hi nielsgerrits
Thank you very much, I understand what I missed :)
nielsgerrits
  • May 16, 2023 8:43 AM UTC
