I am trying to read in a csv and write the contents into a javascript file. It works at least 90% of the way and looks like this when I export the features:
[ { feature1: value1, feature2: value2 }, { .... } ]
I would like to insert the text "var data = " at the beginning of the file, like so:
var data =[ { feature1: value1, feature2: value2 }, { .... } ]
Is it possible to insert this text in the file before the JSON writer writes out the contents?
Another detail is that this CSV file has over 5 million rows. It is difficult to open the file and write in the text or use powershell commands. Any help is appreciated!
