Window task scheduler
  • Sep 22, 2020 3:12 PM UTC
  • 135 views
I am using FME Desktop. For my data source I am using MSSQL_JDBC_NONSPATIAL_2. I am reading the data from the data source and copying it into the Socrata platform using the Socrata writer. I copied the first four lines of command line code, pasted into notepad and saved it in the same location as the FME file. When I run window task scheduler. In command prompt, it reads.
Reading...
Emptying factory pipline...
Translation was Successful
Then get the following message directly below it.
C:\\drive........etc.
''--SourceDataset_MSSQL_JDBC_NONSPATIAL_2' is not recognized as an internal or external command, operable program or batch file.
C:\\drive.....etc.
'--DestDataset_SAFE.SOCRATA.SOCRATA2' is not recognized as an internal or external command, operable program or batch file.
I cannot tell, if that is an error message and the task scheduler failed or if that is normal? Thoughts
Best answer by david_r
Try putting all four lines on the same line, separated by spaces.
Example:
c:\...\fme.exe
--option1 ...
--option2 ...
becomes
c:\...\fme.exe --option1 ... --option2 ...
  • Sep 22, 2020 3:33 PM UTC
Example:
c:\...\fme.exe
--option1 ...
--option2 ...
becomes
  • Sep 22, 2020 9:47 PM UTC
That worked. Thank you
