Why is the download URL not being returned in an FME server app?
  • Jun 16, 2021 3:56 PM UTC
  • 331 views
paul.wittle
I created an FME server App that runs a workspace. The workspace generates a Zip file but I could not work out how to set it as an output so I could define it as the download content.
As a work around I put in a FileCopy writer to simply make a copy of the zip file as that transformer is recognised as an output when publishing to the server.
It has worked once as far as I can tell but in most cases when I run it I just get 'Completed' but no download link.
It is odd because there are no errors in the log when I look at the completed process. How do I ensure that a Server App returns an error (if appropriate) or ensure the Download URL is always shown?
hkingsbury
Forum|alt.badge.img+73
  • Jun 16, 2021 11:50 PM UTC
You need to make sure you've selected a Data Download Service when configuring your web app
paul.wittle
Hi, just to confirm that I have already selected Data Download (and also tried Data Streaming). I don't think the issue is with the settings but I wonder if it is more with using FileCopy as an output writer. It returned the URL at least once but not since.
