Why do readers convert boolean ( example 0) into 'No'? i want to keep it as in de source.
  • Jan 12, 2023 8:58 AM UTC
  • 8 replies
  • 353 views
dannykgf
Source
SourceFME reader
Forum|alt.badge.img+63
Which format is this?
dannykgf
  • Jan 12, 2023 9:37 AM UTC
i am reading from aan MSSQL DB and the format is Bit. In de MSSQL DB is the value 0 or 1. But if i read it with a FME reader i get for the same column 'Yes' or 'No'. How can i get the same as in the source with '0' and '1'?
danminneyatsaf
Forum|alt.badge.img+13
Hi @dannykgf​, I've just tested this in FME Desktop 2022.2 and can confirm that this looks like a bug. Sorry about the inconvenience. I've created a ticket to get this resolved (FMEENGINE-76082). We will notify you here as soon as the bug has been resolved in a new version of FME.
dannykgf
  • Jan 14, 2023 2:08 PM UTC
Thank you @danminneyatsaf​ !
Do you think there is any workaround?
Thank you in advance!
danminneyatsaf
@dannykgf​ You could try using the AttributeManager to change the value of the attribute that contains bit data.
You could use conditional values so that if the value = Yes, then it sets it to 1, and if the value = No, then it sets the value to 0. See the screenshot below:
Unfortunately, there aren't any more automated/intuitive workarounds that I am aware of at the moment.
dannykgf
  • Jan 17, 2023 10:52 AM UTC
boneill81
  • May 26, 2023 12:13 PM UTC
Hi @danminneyatsaf​, I was wondering if this had yet been patched? I ran into it this morning but I have tables with quite a few BIT columns and it will be tiresome to have to create conditionals for each column. Thanks.
danminneyatsaf
Hi @boneill81​ unfortunately, the team is still investigating the issue. If this change were to take place, it would affect more than one format which means more investigation is needed before we can commit changes.
I agree that having to set conditional values on each column is a frustrating workaround. I created the BooleanValueMapper transformer on the FME Hub to make this process easier. With this transformer you can make changes to all your attributes (or all your Boolean attributes) in one step. The transformer allows you to provide what value you would like to map your Boolean values (0 and 1) to.
