verify file header
  • Apr 7, 2020 9:26 AM UTC
  • 157 views
maica
Forum|alt.badge.img+4
Hi, I would know if exist a transformer that verify if file header is correct. Thanks
itay
Forum|alt.badge.img+19
  • Apr 7, 2020 9:29 AM UTC
Hi @maica,
Can you provide some more info? what kind of file/format? what is a 'correct' header? and can you provide a file to test?
maica
  • Apr 7, 2020 9:41 AM UTC
Hi @maica,
Hi, the file is a simple csv that has a header. I would the ETL fails if the header change.
  • Apr 7, 2020 1:36 PM UTC
One way to validate a CSV header might be to use a dynamic CSV reader followed by a Tester to check for "Attribute is missing" on the attributes you expect to find in the CSV.
itay
  • Apr 7, 2020 1:55 PM UTC
You might want to have a look at the Schema (Any Format) reader. This reader returns the data model (schema) of your input as a list.
You can then compare this list to a list of expected attributes, something you can use the ListBasedFeatureMerger transformer for.
