Using PointOnAreaOverlayer, I would like to know how to extract polygon IDs and assign them to corresponding points that are within each polygon.
Best answer by geomancer
Under Attribute Accumulation enable Merge Attributes. All attributes from the polygons will be copied to the points that are within that polygon.
POAO_Merge_AttributesIf you have overlapping polygons, enable Generate List On Output 'Point', and enter the appropriate settings.
geomancer
Forum|alt.badge.img+51
  • January 5, 2023
  • January 5, 2023
It worked! Thank you so much.
